Red dust coming off chain??
11K views 16 replies 12 participants last post by  Kopke
#1 ·
I have this red powder, consistency of baby powder, only red, coming off my chain ('00WR400 BTW). It's all over the sprocket cover, rear/front sprockets, and some on the swingarm. It's a non-o-ring chain....and it's been stretching like a mofo...every ride it gets worse and worse.....
Any ideas?
#4 ·
new chain, cleaned, lubed, adjusted after every ride (factory manual specs @1-1 1/2" at the slider), I haven't gotten caught in the rain yet on this bike (I hear that shit's dangerous, you could lose your wallet, or worse, your girlfriend). and the bike has maybe 500 mi since conversion to SM, so that's what's on the chain I got from motostrano.
I'm overly anal on the maintenance of my bikes, this thing has had it's oil changed 3 times in the last 500 mi, and 2 filters. I'm using maxxis chain wax, after cleaning with WD40.
#6 · (Edited)
I know you have a none o-ring chain but my o-ring chain did the exact same thing before it died. Apparently it was the stuff they put between the pin and the "sleeve" (not sure what you call it). For o-ring chain they start coming out when your o-rings fail and can no longer seal properly. Maybe they put the same stuff on your chain for some reason? and since its a none o-ring chain is just spits them out since new. I remember looking down at my bike thinking why's everything red around the drive! and about chain stretch, maybe depending on the brand? On my trials moto the chain stretched every ride for a while (I think regina). I had to readjust quit often then one day it just stopped and have been riding that chain without adjustment for a couple of months.
#12 ·
Well...here's an update....
I took the chain off, soaked it in degreaser, then hung it on a board, rinsed it, soaked it in kero, wiped it down, ran my fingers over each link (found that a few were seized already) sprayed it down with wd-40, waited for it to penetrate, wiped it down again, put it back on the bike, properly adjusted, ran it around the block a few laps, up on the stand, loaded it up with Maxxis chain wax, let it cool/cure, removed the chain, flipped it, re-installed it, ran it around the block again, loaded it up with Maxxis again, let it cool........
Rode it 100 mi since, the dust is gone, the links are loosened up, and all is well, the bike "feels" a little better now....
On the flip side, on my R1, stock chain, I've only adjusted the chain when I've replaced tires......
weird, because that bike (R1) makes a shit-ton more HP than the WR, but doesn't stretch the chain at all......
#14 ·
It is normal for the chain to stretch for a while when new. It should stop after say 1000 miles or so, mine stretched a hell of a lot when i first bought my bike. Just make sure you stay on top of adjusting it until it stops stretching so much. My chain takes a beating between coming hard out of corners and dropping a couple gears into them...It is much different than a sport bike even though they are heavier and make more power.
#15 ·
Probably should replace that chain, it may be ok now but its toward the end of its life from what you were describing, the dust was rust from inside your rollers more than likely the siezed ones. I've had chains go 12,000 miles without a hickup and I've had a chain shot out and kinked in 5,000 miles, and I am the same way with maintenance all it takes is for one little drop of water to get stuck in a roller and its game over.
#17 ·
A good chain wax will give the longest lubrication; as soon as the lube is gone the fretting will be back.
You really can't keep enough lubrication in the links of a non o'ring chain to totally prevent the fretting.
I had the same problem on my XR 650; got a non o'ring chain by misstake and ran it anyway; never again!
