Kawasaki KLR 650 supermoto wheelset
2 reading
6.6K views 2 replies 3 participants last post by  maverick9611
#1 ·
Warp 9 KLR 650 supermoto wheelset. Previously installed on my 2008 KLR 650, but will work with ANY klr 650 because of everything included. Less than 4,000 miles. Avon distanzia SM compound tires front and rear. Front tire has a few thousand miles left. Rear tire has a couple of rides left (need a new tire). Includes warp 9 320 mm rotor (NEW) and caliper relocation bracket, warp 9 stock size rear rotor, and a stock 43 tooth rear sprocket and carrier . Uses stock wheel spacers (not included).
from the website:
Warp 9 KLR650 Supermoto Wheels Warp9 supermoto wheels are a great deal for racing or street! the front will come the 320mm floating rotor standard with a matching rear rotor. the rear wheel is Cush drive and will accept the oem Cush system or you can purchase the Warp 9 Cush carrier separate. the front rotor has a hole in it to accept an ktm/trail tech magnet if you are running an aftermarket electronic speedo the front hub is machined to accept the oem speedo box also. Great supermoto wheels for street or racing and backed with great service and support.
17x3.50 front mated with a 17x4.25 rear. supermoto wheels
Anodized 7000 Series Aluminum Rim.
Stainless Steel Spokes and Nipples
Aluminum Hub with stock or high-quality chrome appearance but Stronger
Stainless Steel Wave Brake 320MM Rotor
Anodized Brake Caliper Relocator
Rear Steel Rotor
NAK Seals
OEM Bearings
List Date: 8/10/2015
For more info, click here to view the original listing: Kawasaki KLR 650 supermoto wheelset
This item is no longer available.
Mobile friendly version: Kawasaki KLR 650 supermoto wheelset
Go Mobile: Download the free Panjo iOS app now!
