1 - 17 of 17 Posts
Discussion Starter · #2 ·
Finally got an engine, it’s an early version 685cc but perfect to start off with
Engine cast sand cast cases, lot of heft in them, not the normal paper thin die cast Japanese, since photo’s I’ve stripped the engine down to bare cases stripped ugly paint, aqua blasted them
New bearings on there way only German/ Japanese no Chinese rubbish
Custom CNC S/A spindle / axle being machined this week
More pics coming ,,,,
Drilled cases halves 25/32” then 20mm with hand Reamer
Next will be machining down the case width to match Vert’s S/A
Cases have corse sandcast finish, so I will be painting them
Base Transfers cleaned and radius, Cyl’ base and case halves lapped,
Nature of custom work it’s not always obvious where problems are until parts
Hence I cannot use the Vert S/A as it’s large O.D bearing boss will not clear the clutch side of case, so now will use VOR Billet S/A which does clear with a little clearance grinding of the case and S/A radius
Holy fuck this is gone be one sick ride. Is it gone be street legal or just track use?
Yes, it was already road registered before,,
Mocking up continues,,, for kickstart shift clearances of frame spar
Wow... can't say I've seen anyone use one of those engines before. If I recall that's the maker of the engine in that old side car dirtbirk race series. Can't think of anywhere else I've seen them used. In any case that's a pretty cool engine and is going to make an amazing build. The build quality of it looks awesome, like it could really take a beating - and probably run forever too with proper maintenance.
Will check back on progress.
Well I’m certainly not the 1st, quite a few on YouTube using Zabel in KTM 250, CRF Husaberg etc
But I hope mine will go a step beyond just making it fit and run ,,,
Sick build! What kind of gearing does the trans have, close or wide ratio?
Discussion Starter · #12 ·
The 685cc has 5 speed, later 700cc are 4 speed I haven’t analyzed the ratios yet
From others gearing not much an issue has the have broad torque band
Discussion Starter · #13 ·
Cases back from CNC Machine shop steel top hat swing arm bushes installed, painted Vertemati magnesium color
Now waiting on CNC shop for swing arm work ,,,,
Discussion Starter · #14 ·
Crank runout 0.001”
End float needs shims
Finally the S/Arm fits, tiny bit of die grinding was required
The Donor awaits well 1 of them
This early engine came with option to have kickstart on either side, looks like I’m going RH side
Bit of lower cradle clearance cutting and grinding, plating reinforced required in 4130 steel
Next onto the scallop cut clearance for the kickstart lever swing
Discussion Starter · #15 ·
They are close ratio. Just looked at ratio range, hence why later 4 speeds lost 1st gear
1 - 17 of 17 Posts
