YZ426 7/8" Scotts Damper bar mount. Clean. $35
should fit any YZ / WR 250 / 426 / 450
YZ426 1 1/8" fat Scotts Damper bar mount, surface scuffs, Functional. $35
YZ426 Scotts neck post, needs new bolts (heads stripped out a little). $25
YZ426 EBC 320 ROTOR. OUTER ROTOR IS DISHED IN TOWARDS WHEEL FROM OVERHEATING. Very useful if someone has a good rotor with a torn or damaged center section. CENTER IS STRAIGHT. $30 OBO.
Discussion Starter · #2 ·
YZ426 320 spacer for stock caliper... should fit the typical:
YZ / WR 250 / 426 / 450 - Verify on the 450's first though as i'm not sure.
$25
small headlight designed to fit on a fiddy for hooligan runs through town... never mounted, custom made by myself out of aluminum. i think theres 2 35w lights, one with a medium tight beam and the other with a medium wide flood... not a real wide flood, but useful...... run both at the same time for super excellent lighting.
No way to mount it but the two bolts run through and you can use a little ingenuity. this is ONE OF A KIND, and looks cool on the front of a fiddy. Polished on the front and the jaws are bead blasted.
$50 + shipping.
over sized bar mount and post clamp sold to whodat.
7/8 bar mount and fiddy headlight and warped rotor still for sale...
any offers on the rotor will be considered. Hat to see the good half go to waste.
