1 - 20 of 52 Posts
I’m putting everything needed to turn your 06-08 YZ450 (or 07-09 WR450) into a competitive supermoto racer (some parts may fit other years). All items listed below have less than 10 hours use (some items even less) and are in excellent condition. All items were previously installed on my 08 YZ450. Would prefer to sell locally (Redondo Beach, Ca) but will ship certain items. All items have been removed from bike and are ready for sale.
Wheels: Factory Pro Racing wheel set. 3.5x17 front and 5.0x17 rear. Wheels are comprised of Rad Mfg. hubs and Excel rims, stainless spokes and nipples. Hubs and rims are black in color. Currently have Bridgestone Battlax supermoto slicks mounted (good for 2-3 more track days). (Note: different wheel spacers will be needed from Rad to fit early YZs and WRs) New $1000, asking $700 (tires included).
Tire: New Bridgestone Battlax Supermoto front tire. Super soft compound. Asking $125.
Brake: Magura supermoto radial brake kit with 4 piston radial mount caliper, 12mm model 195 radial master cylinder and less than 1 hour on the new Magura 320mm floating rotor (radial mount caliper bracket will fit 08-09 YZ450 and 07-09 YZ250). Unbelievable stopping power! New pads installed in caliper and new spare brake lever. New $1300, asking $800.
Master Cylinder: Magura 13mm master cylinder, model 195 (new in box, includes lever, no resivoir). New $270, asking $200.
Triple clamps: 13mm custom machined offset triple clamps (fits 08-09 YZ, will fit early YZ and WR with 1mm wider disk side wheel spacer or 1mm shim). Uses stock bar clamps. Greatly increases front end stability and confidence while cornering (stem and bearing are not included). New $450, asking $300.
Slipper clutch: Surflex slipper clutch. Comes complete with clutch pack and all hardware/mounting instructions (less than 5hrs use). Completely eliminates rear wheel hop entering corners. Will fit 06-09 YZ450s. New $790, asking $500.
Piston/Cams: JE 13.5:1 piston kit, Hot Cams intake and exhaust camshafts and Cometic gasket kit (all new in box, never used). New $675, asking $450.
"SOLD" Sprockets: 14, 15, 43, 45 Sprocket Specialist hard ano black (15 and 45 used for approx. 1hr, 43 new). New $160, asking $75 for all.
"SOLD" Sliders: SM Engineering F&R axel sliders, bar sliders and additional rear axel slider (some scuffs). New $220, asking $70 for all.
Footpeg sliders: 1 set (and one spare) Praire City SM universal footpeg sliders with J bolts, new. Asking $15(footpegs not included).
"SOLD" Catch tanks: Custom made CC breather, coolant and fuel catch tanks including all plumbing and brackets. Asking $50
Feel free to contact me with any questions.
John
sending pm
I believe so. The only difference as far as I'm aware is Yamaha went with one less friction and metal plate in the stock 08 clutch which wasn't necessarily a good thing. Surflex uses a stock clutch pack that's included with the unit so should bolt right up.
Shouldn't be a problem.
John
SSchafer5...your mailbox is full. I've tried sending you PMs but they're not getting through.
John
Sliders, and the catch cans are sold :bannana::bannana:
Discussion Starter · #12 ·
Yes, in fact that is where they will be headed if they do not sell here. They'll find their way into my WR450F.
John
Discussion Starter · #16 ·
They are considered stage one cams so they are safe to use with the stock valve springs.
P/N 4022-1E Exhaust and 4023-1IN Intake.
John
1 - 20 of 52 Posts
