Hi all, was hoping to find anyone that could help me diagnose what is wrong with my yz before I take the clutch out and have a proper look.
A couple of weeks ago I took her out for a spin around the back lanes..after about 5 mins of riding the bike suddenly went stiff and started making a horrible rattling/grating sound. I assumed that it was something in the top end, but when i went to rebuild the only signs of wear i could find were the small end bearing had been very slightly crushed or something causing one of the rollers to seize in (very minor damage). There is also no up/down play in the conrod. and no play in the flywheel either.
I checked the barrel for marks and couldnt find anything, apart form a tiny little chip by one of the ports that is well smoothed off and has clearly been there for a while..,I put in the new piston, ring and bearing whacked the barrel on and gave the kickstart a hand push to check for resistance in the top end, there was none.
When you try and start the bike the kick-start seems a tiny bit stiffer than normal, the bike needs throttle to run and as soon as you let off the piston stops fairly abruptly.
http://dw3.convertfiles.com/files/0204583001306267752/voice000.mp3
^^Thats a sound clip of me attempting to start it. Im thinking that it could be the kickstart idle or primary drive gear as I have been riding it on the road alot and this would put more stress on them?
Any ideas/advice would be much appreciated!
Thanks in advance
Holy crap, that does not sound good.
I wish I could help but I am a noob in mechanics.
You might want to contact nunyah as he seems to know a lot on those machines.
Youre right, it does not sound good atall :/, especially considering it happened just before I managed to finally get her road registered. Have been waiting to take this bike on a decent road for ages!
