need to clarify some things..
the review posted on xr.net is simple enough..but this one is a little different =specifically= '2)' & '2A)'.....
http://www.qsl.net/n5nj/pig/uncorking the brp.htm
***Remove the top of the carb and...
=2) Replace the needle using the needle from Part # 16012-MBN-641**
Clean the slide with carb cleaner.* Reassemble the top cover.
Flip it over and remove the bottom cover which is the float chamber.**
=2a)Replace the needle seat from Part # 16012-MBN-641 (B53E)
3) Replace the main jet using part # 99101-357-1750** (#175)
4) Replace the pilot jet using part # 99105-MBN-0680* (68s)
also.. i saw another post on the net where a 68s pilot jet was installed and the pilot screw was backed all the way out.....
.........why back it out all the way?
-i have a 68 ...is it the same as the 68s?
-i live in the northeast.. is the 172 a better jet to use than the 175?
-can the thermostat be taken out all together or should it be replaced?
.. thanks for all the info - i dont mean to be so obvious with my questions - just well informed..
:hammer:
:hammer:
