Got a question for you guys. I just removed a smog pump off a XR2001 650L non California model.
Could someone please tell me where the small vacuum line that goes to the back side of the smog pump, where it goes now with the block off kit? Or does it get plugged?
Also, on the crank case vent. Do you drill a hole in the air box and run it back into the air box?
On the Left side of the bike, mounted in front of the air box is a part off the smog setup. It has a hose inlet on the bottom and the top. Is this used for anything after the smog kit is removed?
I am assuming that the round canister that mounts in the rubber bushing attached to the bikes frame is the charcoal canister. Is this correct and if so, is this used or should it be taken off?
Thanks!!!
[email protected]
Thanks!!!
[email protected]
