Do you know if the set I have on my 01 426 will fit on an 05 YZ 125? If so I will get the 125 fo sho!:thumbup:98 YZ250 uses a 20mm axle and 99 and up use a 22mm rear axle so make sure you get the right year. The front will fit from 1996 and up with the right spacers. Hope this helps your search. WD
Thanks for the info. Now the 426 will get the complete tear down she needs and the sumo set up will go on the 125. Sweet.The 01 wheels will work on your 05 no problem. You will need front wheel spacers from the 01, as the 01 front hub is narrower than the 05 front hub. Rear hubs are the same from 1999-2008.WD
