Just finished installing a set of cycra pro bends on my WR-X. I'm running Pro Taper SE CR high bend bars (7/8). Left side mounted fine, right side is not so good. Having issues with the lever being long (will cut down) and seems the brake reservoir is just plain in the way. I'm using bar mounts not triple clamp. Wondering if anyone else has had any issues or any ideas.
I've had to bend them outward at the bar mount and run longer bolts with spacers. However much clearance you need, just run an aluminum spacer that long between the bar mount and the pro bends. I only needed clearance on the brake side but did both sides so it was even!
I ran the triple clamp mounts and they bolted up just fine!
Pics of the gaurds? i have only read about them.. been wanting to upgrade my acerbis sm gaurds they are pretty busted up def done there job.
