Left key on the other night which of course drained the battery. Charged battery and starts and runs fine, but speedo display shows only "E" and no error codes.
Do I need to reset something? Manual and web searches yield lots of info on specific codes, but I don't even get a code.
I've left my key on and killed the battery at least a half dozen times. Never seen said E code. Go to your local shop tomorrow and just get them to look up what the code is.
Dealer recommended disconnecting battery for a couple minutes - then reconnecting.
I did so and had no display for about 5 miles of a ride, then "E" started flashing again. I found this thread over at WR250 forum which states that electronics on the X are pretty fussy. http://wr250rforum.forumotion.com/t5263-speedo-reading-3x-actual-speed-after-batter-change
Now I'm torn, do I?
1. Bring into dealer and find that $100 later I need a new cluster for $400
2. Buy a used unit off ebay and potentially have the same issue
3. Go with a trail tech aftermarket $100-$200 (any one having any issues with these units? / what are you gaining e.g tach, etc VS giving up e.g. Diagnostic error codes).
