I have a Street legal wr 426 and it is a mad bike. I'm not old enough for a car licence and I use it to commute to work in sometimes -6 Celsius so I was wondering how I can add a set of heated hand grips onto it when the bike has no battery? Where can I find auxiliary power to hook these up? I was thinking of installing the Kind that just slip under the existing grips. Anyone know where to start with getting power to them? Thanks :)
I had those on my DRZ - the cheap ones that slip under your grips. They worked okay, probably work better if you have handguards as well (I didn't). You have to find out how much output your stator puts out and make sure you have enough excess to run the warmers. They'll state how much power they draw.
I wired mine in parallel with the headlight then added a couple switches so I coułd run the light or grips independently or together.
