1 - 13 of 13 Posts
Anybody know anything about this bike, looks way too good to be true?
saw it on another forum
If you are looking for the fastest production super bike, the X18-R Nitro ( Race Edition ) is it! Powered by a newly retuned and tweaked Honda®-Based 110cc 4-Stroke Engine, this super bike can reach stratospheric RPMs in only a few ticks. The needle sweeps the 70+ mph top speed quicker than any other super pocket bike available. A Race-calibrated carburetor and max air velocity intake system ensures that the X18-R will be the dominant force to be reckoned with wherever you go.
The X18-R's frame and sub-frame was designed from scratch using the latest CAD systems. It's slippery profile produces one of the lowest drag for the best in aerodynamics and stability. Partner that with the Race-prepped suspension system (infinitely adjustable) and you get one of the most stable super pocket bikes in the high-speed sweepers and in the tightest of corners.
Front and rear hydraulic brakes and Racing calipers stop the X18-R in record braking distances. Grab the left hand lever to feel the difference a Racing clutch makes. Mated to a 4-speed Sequential Manual Gearbox (gear selection digitally displayed on dash), upshifts and downshifts happen in mere milliseconds. Acceleration is strong in any gear because of the X18-R's revised torque curve, which provides maximum power even at lower RPMs. The large diameter free-flow exhaust screams a melodious note at wide-open throttle while staying relatively quiet at idle and low revs.
Every option has been included with the X18-R. A full array of gauges on the backlit dash relay information to the rider including speed, current voltage level, warning lights and an LCD digital display of the current gear selection. The electric start button, Quartz headlight, signal, tail and brake lights are all ergonomically located at your fingertips. All ACC items are fuse protected, key activated (anti-theft) and charged via the ZR motorcycle alternator. The non-slip leatherette seat and fully adjustable controls (handlebars, brakes, levers, suspension, tire pressure, etc.) guarantees a customized fit for any rider.
The X18-R (Race Edition) Nitro Super Bike comes fully assembled and ready to ride. All upgrades and performance parts are OEM factory installed and tuned for maximum gains and reliability. With numerous Race-prepared modifications performed to the engine and powertrain, the X18-R dominates all other super bikes at the track!
EPA APPROVED & CERTIFIED - OUR X18-R SUPER POCKET BIKE IS EPA APPROVED
CLICK HERE FOR A COMPARISON OF OUR 4-STROKE BIKE VS OTHER SUPER BIKES
CLICK HERE TO SEE EVERYTHING THAT IS INCLUDED WITH THIS 4-STROKE SUPER BIKE
IN STOCK! USUALLY SHIPS IN 1 DAY
$ 579.00 $999.00
Drivetrain
Engine: 4 Stroke 110cc Single Cylinder, Air Cooled
Fuel : 91+ Unleaded Gasoline (no oil mixing required)
Starter: Electric Key Start With Backup Kick Start
Maximum Speed: 70+ mph
Ignition: CDI, Ultra High Discharge Coil
Transmission: 4-Speed Manual With Hand Clutch
Maximum Power: 15.2 hp
Brakes: Hydraulic Cross-Drilled Disc Brakes
Exhaust: Factory Tuned Racing Pipe
Dimensions
Length: 58.5"
Width: 26"
Height: 34.5"
Ground Clearance: 6.5"
Dry Weight: 149 lbs.
Weight Capacity: 395 lbs.
Fuel Tank Capacity: 2.25 Liters
Cruising Range: 48 miles per tank
Tires: Pneumatic Racing Treaded Tires
Included Free with 4-Stroke Super Bike: Individual Keys (2), Tools (sockets, screwdrivers, allen wrenches), Tool Case, Spare Fuses, Owner's Manual / Certificate and our free extended warranty.
15.2 HP/ 70mph??????
I don't see what's so exciting. There are countless other pocket bikes out there just like this one. The only difference is this one is decently marketed in english (read: lots of fancy suedo-techincal talk), rather than roughly translated in engrish.
Seriously, most of that is a load of crap. How much drag testing do you think they did on anything that costs $600? Even if it did, how much of a difference would it make on something that small and only hits 70?
And I like the talk of the sequential transmission. That is new and exciting. It's about time they put one of those in a motorcycle. *cough*
In short, if you want something moderately fun and cheap, I'm sure it'll be fine. But if you really buy into all that hype, then good luck.
150lbs pocket bike? Does that come with a 20,000lbs tensile strength belt?
Discussion Starter #7
Found a site that has lots of info about it, basically it's what you would expect for a $600 chinese bike. real hp-6-8; top speed stock 45-52.
Couldn't believe the hype especially when Pitster advertises their 08 top of the line X4 with the new 150 cc GPX motor putting out 11.9hp tops/ 45mph top speed for abot 4 times the $.
Outrageous how bad advertising has got, no better today than the snake oil salesman in the 1800's.
Pitster bikes are bad arse for the money :thumbup:
x18 is a piece of shiit bike. Cheap ABS plastic fairings, crappy frame, brakes that will not brake. Most come with a loncin 107cc engine, not 60mph at all. Save your money.
Tallboy, blatas are the cheapest quality of the european pocketbikes. They are poor machines in my eyes. there are many quality brands such as, GRC, GEM, BMS, Pasini, Stamas and Giannini.
:laughingr:laughingr:laughingr:laughingr
Maybe if by "dominant force" you mean "laughing stock!"
$ 579.00 $999.00
Drivetrain
Dimensions
Length: 58.5"
Width: 26"
Height: 34.5"
i want to make an offer
1 - 13 of 13 Posts
