I'm using a set of 17 SM wheels from a 450exc for a DRZ. I need a 240mm rotor for the rear. I can't seem to find a KTM that has a rear 240mm rotor.... Am I overlooking one or does such a thing not exist?
not overlooking just not existent.
The 240mm rear rotor is needed because of the lack of power that caliper has. The Brembo on the rear of KTM is really overpowering and more than what is needed really.
KTM's been using that 220 rear for over 10 years and it has worked damn well too. Good luck on your test....
Found a thread saying these have a 240mm but not sure if the bolt pattern will be the same on any of them as the hub I have..
KTM 240
SX-F 450 07-08
690 Duke 08
690 Supermoto 02-08
690 SMR 07-08
950 SM 05-07
950 SMR 07-08
Superduke 990 05-08
KTM 690 Rally Factory Rep 07-08 240
950 Adventure/S 04-06
KTM 690 SMC 08 240
KTM 240
SX-F 450 07-08
690 Duke 08
690 Supermoto 02-08
690 SMR 07-08
950 SM 05-07
950 SMR 07-08
Superduke 990 05-08
KTM 690 SMC 08 240
DM,
I think you are right on this one. pretty sure the bolt pattern is the same, BUT i just bought a rear rotor for a spare off a newer Berg and the bolt pattern is different and will not work........mihgt check with GWR on KTMTalk. Glenn can tell you anything.....about KTM that is.
Moderator
KTM 240
SX-F 450 07-08
690 Duke 08
690 Supermoto 02-08
690 SMR 07-08
950 SM 05-07
950 SMR 07-08
Superduke 990 05-08
KTM 690 SMC 08 240
list is wrong, only the lc4 series have a 240 mm rear rotor but the wheels are different as well, don't know if the bolt pattern is the same. 450 sxf, doesn't matter what year, has a 220 mm rotor.
Discussion Starter #6
Thanks. I started looking at the KTM parts fiche and noticed that someone didn't know what they were doing when compiling that list :lol:
I'm probably going to go a different route now and switch back out the swingarm so I can run a 220mm.
