Hello all and thanks in advance for help! So I'm having issues fitting the rear rim. 17 x 4.25 warp 9 rear which I'm putting on my 15 KTM 690 enduro R. So the 6 bolts on the abs ring touch the bracket caliper bracket. Once the Axel is tightened the wheel has no movement what so ever. It's the difference of maybe 2 mm's? I contacted warp 9, told them about the issue and was only sent the same damn bolts which didn't help me anything. I've also attempted putting the stock rotor and abs ring on the rim and no luck with that either. Any help would be appreciated, I am currently trying to get in contact with warp 9 a second time to see what they have to say.
