I just got the temp sensor installed in the ol 99 WR400. The trail tech vector is what I am reading speed and temperature with. I set my warning on the temp sensor to 200 and the danger setting to 220. If you are running a vector and using the temp sensor, what do you have your temp warnings set too? Thanks in advance
Think my warning is at 220 and danger at 240. I think I hit 220 once at a long light. MY TL would get up to 220 easily.
I set my settings to 200 for the low and 220 for the high. Went for a test ride and the bike runs about 115-120 degrees cruising at 55mph. Went through some twisties and got it to go up to 130 for a second. I am sure the temps are so low because of no thermostat. Also, installed engine ice at the same time as the temp sensor. Bring on summer!!!!
