No simple projects...
As usual, there are no simple projects, the Trail Tech is now working great, but I have a few lesson learned that I would like to share if you get to install one. First TrailTech has a great FAQ http://www.trailtech.net/faq's.htm, among which: “How can I be certain the magnet and sensor are lined up correctly”. The diagram showed the sensor/cable assembly perpendicular to the magnet path and above the magnet path. I drilled a 1/8 hole and installed the trailtech sensor/cable assembly at the bottom of the MotoMaster relocation bracket (see picture) so that it is protected and easy straight wiring of the cable alongside the brake hose (I knew it was not perpendicular to the path). I then used the magnet bolt on the rotor and could get a pulse when spinning the wheel, so far so good. First bad news, I broke the magnetic bolt head, before I even had a chance to pick my torque wrench…they gave warnings, but boy they are fragile. Well, I then used epoxy to glue one of the provided magnets to the brake rotor. I was happy and went for ride to find out I was getting a double pulse (as they warned us…). I had to break the epoxy, and glue the magnet as low as I could (see left of the fork on the photo). So, first big lesson, don’t put the sensor/cable assembly were I did, I think and ideal location would be to drill on the “-“ of the SM-101 mark. As for the display unit, I simply tied it on top of my original odometer (I still want to be able to convert the bike back to dirt riding quickly). Finally, in theory, a 120/70 tire on a 17” wheels has a circumference of 1884mm, in practice you have to take into account the tire pressure and all sorts of crap. I measured ten rotations of my front wheels on my driveway, and came up with 1850mm which seems to about right (I mounted Kevin’s GPS on my handlebar to verify it…). That’s all folks…
