I have the 1-3/8" Easton Fat bars and after searching I realize that all the Trail Tech Gauges mount to a 1-1/8" bar.
Has anyone mounted the Trail Tech gauge to the stock husqvarna bracket?
My speedo was missing when I got the bike. I made a custom mount with 2 small tabs, attached to the upper 2 bolts on the bar clamp. Very ridgid.
Looks awesome.
Did you just buy a piece of aluminum plate and go to town with the dremel?
What thickness did you go with? Did you get it from McMaster Carr or did you pick it up locally?
I used 1/2" X 1/8" stainless because It's available at work. I welded a thin ss flat washer to my tabs and ran the clamp bolt through them. As short as those tabs are, the same size aluminum should work fine. If you go any thicker, you will compromise the thread bite on the clamp bolts.
Make sure the hole centers are dead nuts on both pieces, that way your Vapor will be squared up.
