I have a smr 510 10’, fresh rebuild etc.
It will crank forever but not start. I’ve read about timing being 180 off, but i can’t seem to understand it. I did make the mistake of not checking if i was on the compression or exhaust stroke When installing cams.
Would 180 degree off mean i should take the cams and rotate them 180 degrees them mount up? But then i wont know if im hitting the right tooth on the freewheel because the circle on the cams would be at the opposite side? I’ll post some pics too. The first pic is the engine now. On tdc. I dont know if its the compression stroke or not, but i think it is. Second pic is the bile before, not on tdc for referance.
