61 - 80 of 91 Posts
I also found out from my local husky dealer that ARC makes shorty style adjustable reach brake and clutch levers for the SMR 450 and 510. Here's a link to ARC's website: http://arclevers.com/index.php?route=common/home
I believe the brake lever is part number BR-103, the long style clutch lever is CL-103 and the shorty style clutch lever is CL-105. The levers come in either aluminum or composite (memory plastic) and have a lifetime guarantee so the website says.
Does any body have a fix for these threaded inserts on the gas tank.
My left side shroud is just spinning. This one is pretty much done, as you can see.
And no I did not any locktite on them.
im new to the forum i figured this would be a good place to ask, but im looking for a stator for a 2007 husqvarna smr510
Thanks for the list/ info, guys
Power Upgrade - 2004 Husqvarna 450 SMR
Hey guys! I am looking to do a power upgrade to my 2004 Husqvarna 450 SMR. I was told to purchase the Pro Circuit T-4 Slip-On. Available here http://www.procircuit.com/t-4-slnr-husqvarna-tc450-ft05.html and that I might need to "richen up" Was wondering if this entailed purchasing a jetting kit? I found one available here http://www.ebay.com/itm/230680250107?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649 but I was wondering if anybody had any experience with this item? Also it was also recommended that I can do the accelerator pump modification, what does this entail and how would it function?
For those with questions about chain adjustment on the 450/510... this sticker was on the swingarm of my 2010 SMR510. To me anyway, it reads that you put tension on the chain to make the lower section of the chain fully taut. Then, you take your measurement 145mm from the swingarm pivot axis. At 145mm from the swingarm pivot axis, the upper chain section should have 30mm of up-down movement.
61 - 80 of 91 Posts
