When you install new cams is there a firing stroke that you have to line the flywheel mark up with ?? Only every three revolutions my cam marks line up with the flywheel mark. Its not starting so I think I put the cams in on the wrong stoke.
Discussion Starter · #2 ·
Just watched the hot cams video and I was supposed to find the copression stroke ...Don't remember doing that ! What a dumbass!!! So how do I find that now.
pull the plug put a long screw driver into plug hole...slowly rotate until piston is @ tdc...with the cam lobes NOT pressing on the buckets...your on Comp stroke...
Yeah, thanks I figured it out right away then started right up and felt like a giant boob! OOHH well lesson learned!
