this is what said needed to be safety wired:
• Safety wire – oil filter bolts (0.024” diameter minimum)
• Safety wire – spin on oil filters (requires metal clamps & safety wiring)
• Safety wire – oil filler caps and oil lines
• Safety wire – fork oil drain screws (or secured with Permatex, tape, etc)
• Safety wire – oil drain plug
• Safety wire – masterlink clip (or secured with Permatex, tape, etc.)
now with the sxv am i right in thinking i dont have to worry about:
the masterlink clip because its a continuous chain?
the oil filter bolts because everything is behind the oil filter cover?
the spin on oil filter because it too is behind the filter cover?
now the oil filler caps and lines im not to sure what to do? i was told to drill a hole through the bolt and attach it to something or twist it off? how do i do this for the lines?
also the fork oil drain screws, i want to permatex them but wont that mean id be loosing fork oil in the process?
