1 - 18 of 18 Posts
Besides our normal deals on all slipper clutches by STM, Suter, Hinson and Adige, we have a number of clearance clutches in stock that are on deep discount
Here are the links:
YAMAHA: http://www.motostrano.com/STM-Yamaha-YZ-WR-450F-Slipper-Clutch-2007-2009-p/fya-x120.htm
Husqvarna: http://www.motostrano.com/Suter-Slipper-Clutch-Husqvarna-450-510-610-p/004-27002xx.htm
KTM LC4: http://www.motostrano.com/STM-KTM-LC4-Slipper-Clutch-p/11300090.htm
KTM EXC: http://www.motostrano.com/STM-KTM-450-525-Slipper-Clutch-p/fkt-x070.htm
Save $400 off the standard prices on these clutches.
What would be the suggestion for the Husky 630? They're not listed but use the same clutch basket as several of the other bikes. Harder main spring?
I also recommend the STM Slipper CEB. The one I ordered for my 510 from Husky Factory Racing had the spacer needed for the 630. There are different strength main and secondary springs, so make sure you get the right ones with your kit (tunes the amount of engine braking allowed). It's kind of a pain to put together and it's really important to make sure everything lines up, but it makes a world of difference.
any more good deals on lc4 slippers? i must have missed the last one
Discussion Starter #7
Follow up to this -
Motostrano is now importing STM clutches and spare parts direct from the source in Italy, rather than going through distributors. If you have ever had an STM clutch you know that the US distributors were never able to provide spare parts in event of a worn out spring or crash. We will be importing all the STM line and will work to provide spare parts for your exiting clutches as well.
In addition to STM we also import the SUTER clutches and parts from Switzerland
http://www.motostrano.com/SearchResults.asp?Search=suter&Submit=
http://www.motostrano.com/SearchResults.asp?Search=stm&Submit=
Joe
Discussion Starter #8
As we are now importing STM direct from Italy- we are now getting their Supermoto clutches pre-setup for supermoto with the proper springs. Previous importer/distributors imported only the MX versions of the STM clutches, which either left motard riders using the MX set up, or moding it with different springs. We now offer both the smoto and the mx versions.
Additionally- no previous importer bothered with any spare parts and replacement parts. If your clutch has a broken part we can now get any spare parts you need direct within a few weeks.
Joe
Crf250r stm
I just bought a used STM for my CRF250R off this site.
One spring is cracked.
What parts do I need to rebuild this clutch What are the recommended springs, prices, availability? Anything else?
Chris
Discussion Starter #10
Chris
Chris
You'll need identify what parts have wear or are broken as you have the clutch. Alternatively, you can send us the clutch for inspection and we can create a parts list for you.
Joe
1 - 18 of 18 Posts
