Hi guys, I'm setting up a 2021KTM 500exc Supermoto, just wondering how you guys have your Forks set, what Grade of Fork Oil 7.5 or 10 or ??? What level do you's have your Oil level set at eg: 100mm Std, are you's going 95mm or 105mm (what's your Rider and Gear weight?). I'm considering 7.5 grade fork oil, but undecided on Fork Oil level, this is where I wanted to either compare or get any advice would be a great help馃槉馃槑 Any advise would be greatly appreciated, and I thank you's in advance馃槉
Super Moderator
Depends. Just changing oil height or oil weight doesn't really do anything. Changing the valving to SM valves and spring rates for your weight along with proper sag settings is the way to do it.
I have the same bike and I'm with you on what fork changes we can make to improve the forks for SM use.
