A trip to the local Honda dealer to pick up some oil change supplies as I intended but.... I walk out with a new Bike.. Doh!
FML - okay so if I do this right and push it into the garage it will be camouflaged among the other bikes.. Wife will never notice...?
154725
See ....worked like a charm- no new bike here bike Babe.... LOL...
154726
Well, ..ok wont be hidden for long ..In any event the work has begun.
Completed so far-
Devol Rad Guards
Engine Ice Rad fluid (Did this while i was in there for a temp probe install)
Pro Moto Billet Kickstand
HammerHead CNC Rear Brake pedal Large Tip and Pro spring kit
HammerHead Forged Shift Lever +10
Acerbis Frame guards
Works Connection Skid Plate
Pivot pegs ( Had these laying around So ill give them go)
Trailtech Striker and aluminum mount
GPR 4 Stabilizer w/ under-mount bar clamps (Thought I would change this up since I have only Used Scott in the past)
Cycra Hand guards Ultra Pro Bend
Progrip Pillow top grips (I may change these out for Emig grips I haven't decided yet)
154730
154731
154733
154734
154735
Need list so far, I'm sure I will add more to this over time but for now..
Excel Wheel set & Talon Hubs
Michelin pilot 2C ( don't want to have any- if possible chain rub)
sumo Chain Guard
Frame Guards
O-ring 520 (my current chain is non o-ring)
Front Sprocket/ Rear sprocket (need to research tooth count ideal for Street)
Front brake upgrade ( giving up my OEM set for another project)
Lighting kit
Noob here so Comments suggestions welcom..
Nice bike, cannot wait to see it on sumo set up, for street use I will say 14 front sprocket
and 42 rear it depends on where you use it, on my Wr450f with that combination I can get up to 100 mph, and still got good torque But yours is mx so maybe 40 on the rear will be better
Nice...I just did a DIY tidy tail on my 19' smcr
I just spent about a day or so looking into lighting wiring etc. I think I’ve settled on the 12 o’clock Labs universal rear tail light kit with the upgraded PC board. My intention here is to keep it clean without side markers..
154780
Thank you sir!! I appreciate the tip ! I can’t wait either!! so pumped!!! For the time being this thing will be primarily on the street. I imagine I’ll probably be limited by my five speed trans...Top speed isn’t necessarily a huge concern but I would like to keep the rpm’s as low as possible in too gear.. I do like that torque though?. looking at two piece alum/steel rear sprock I would hate to buy it twice perhaps there’s a gear calculator.. Still researching...
