I had a similar problem on my Yamaha... There are two ways to solve it, you can either dish the wheel over to the right slightly (slacken off the spokes on the left a little and tightn the spokes on the right), or you can space the caliper out using washers on the two mounting bolts (you'll want to use as thin a washer as you can get away with)... Hope this helps.
