my handle bars are crooked. when sitting on the bike and looking down at the bars you can clearly see the compression clicker on the right side. where on the right side it is completely coved.
its a 06 kx 250f
i have pro taper bars.
i replaced the riser for the a pro taper set. thing that that was my problem but it didnt work.
and ideas? need to replace the rubber inserts in the triple?
i need help
mine do they same thing after a crash, i have an 08 kaw 250f. loosen triple clamp bolts and give bars a wiggle and retighten, also loosen bar mounts and inspect rubber cones for damage, if not obvious damage retighten,rubber cones probably just twisted a bit. is your bike a supermoto? if so lets c some pics, not many of us in here specialy 250f's only me and select few i see here.
more than one way to kill the cat? i was instructed to loosen all bolts (bike in stand naturaly) so there is no way that any tension remains on clamps. i think skeletor method works too but one time "my" method revealed cracked lower clamp. anyway, choose either one an i think it solves your problem.
