841 - 860 of 881 Posts
My SMR..
Mods:
Chassis:
Tubeless DID Fa-ba rims (16.5/5.5)
4mm Offsetted sprocket
Chain guide (Huagogo) (the marks on the rim are from when the oem chain guide removed itself)
Andreani Revalved suspension
660 SMC front fender
LiFe Battery
2012-12-13-0144 by okipouros, on Flickr
2012-12-13-0147 by okipouros, on Flickr
2012-12-13-0145 by okipouros, on Flickr
IMG_3973s by okipouros, on Flickr
Engine:
Carillo rod /w prox crank pin
CP 13:1 piston
Oversized water pump
Oil pumps from 09 model
Increased oil pressure
DJH Manual CCT
Moose case saver
Akra System
CRF Clutch Disks
Adige Clutch Spring kit
NTN instead of SKF main bearings
IMG_4118 by okipouros, on Flickr
IMG_4121 by okipouros, on Flickr
IMG_4126 by okipouros, on Flickr
IMG_4114 by okipouros, on Flickr
IMG_4115 by okipouros, on Flickr
Next mods:
side panel holes for extra air flow
Fit lamda bung and tune carburator
Alter head angle by 1* by changing the triple clamps shaft
cut chain
change cam timing
Discussion starter · #854 · (Edited)
Well she's back together:rolleyes:....Thumper Racing big bore kit 499 cc, 14.1 Wiseco piston, more head work/flow bench, Hot Rod, Ti Pin, crank bearings all balanced...Valve springs, 807 Cam...Hi Flow water pump etc etc looking at prolly going up to 195-200 main ? and 42 Pilot..
Took the bike to the track last week, pulled really really hard.....revved very quickly.... I'm thrilled... I'm gonna dyno the bike once its sorted but I'm hoping mid 60's :bannana: Thanks to Ryan P, for building me another stellar motor....and Travis at Thumper Racing for the super duper special top end...Hopefully I can get on the track with a couple buddy's 613's to see how it will hang..:anim_peep:
