I found a local dealer that sells 17x5 rims. would that fit on my drz 400? they are $100 could I put 17x5 on the front and rear? or just the rear? sorry im a newbie.
pretty sure thats too wide for the rear. ususally 3.5 front and 4.25 rear. you'll probably end up rubbing the chain at the very least. and if you use a tire that would normally be for a 4.25 - 4.5 you'll be changing the profile too much and won't get the intended pavement contact. If it's just the rim you need the correct size isn't much more $
I don't but I'm sure it's the same size as everyone elses, no matter how wide the rim is or what manufacturer bike they're on. good luck, i'm sure someone else will chime in
