Guys,
I want to remove/disable the roll-over sensor on the 690. It is installed in a Crosskart and sometimes it cuts the engine in the corners. I am quite sure it is the roll-over sensor that causes it to stop, since the Crosskart does not lean in the corners.
So question for you: Do you know how to disable the rollover sensor? Can I just disconnect it and short two of the wires together or something like that?
Thanks,
Jostein
I would imagine that either completing the circuit or opening the circuit would suffice. That being said, I DEMAND photos of the kart.
Awesome:clap:
I WANT!!!!
That is badass. Never seen it before. what speeds can you run with that, and how's it handle??:D
