I just made a discovery and thought it was worth sharing. I have been trying to clean up the look of my bike and figured I would remove the factory warning stickers all over the place (after having noted their importance:hmmm:). I struggled for ages with plastic scrapers cause I didn't want to risk using solvents and messing with the paint. Mostly by fluke I discovered that kerosene works absolute wonders in the removal process. Just a tiny bit on the edge you start on, it lubricates the scraper so it glides under the sticker (add a bit as you go). My stickers had no substance and crumbled, coming off in little tiny bits. The kerosene won't take off the sticker residue left behind but it saved ages on just getting the sticker off (unfortunately I didn't discover this until I was on the last decal!). I haven't tried this on plastic though so I'm not sure how it would work. Doesn't look like it did anything to painted metal though (it's just a light oil), but it'd be worth trying somewhere discreet first.
Hope this is helpful!
Get a can of carb and choke cleaner, it will take all the residue with the sticker. Soak it, start at one end and then keep spraying at the end you are scraping. Works great! :thumbup:
WD-40 and foam filter cleaner afterward.
easy removal
get a hair dryer and heat it up and it'll pell right off with no residue left over :thumbup:
I gotta agree with kerosene. I used to use jet fuel (which is just kerosene) as a quick fix to get decal junk or whatever off the side of planes. Always worked like a charm.
That's what I've always used - well, just the wd-40 and then wiped down with some windex or something.
