Too keep from melting.
I made a bracket to mount the blinkers, its 1.5" aluminum. If you remove the rear tail light, there is plenty of cable to move the blinkers.
Guess i'll just step through the pics and give some comment.
Bracket I made, later painted, notice that there is two holes where the turn signal mounts, this is because the stock signal has a guide piece of plastic that will fit in the outer hole:
Tail light moved to the side to show connectors
Bracket and lights mounted:
Sideview of bracket and right light:
Clearance of signal and exhaust, plenty of room now:
Pics of finished product:
