Here's a link to there site:
http://www.rekluse.com/e-Axle_mailer4.pdf
The Rekluse e-Axle is an eccentric axle assembly which replaces the stock front wheel axle.
The e-Axle allows the rider to instantly tune the steering characteristics of their motorcycle
to meet changing riding conditions. Within minutes the rider may adjust the e-Axle over a 4
millimeter range, achieving instant trail adjustment without the cost and hassle of offset triple
clamps. There is no perfect offset for every rider or every riding condition. Only the e-
Axle makes it possible to instantly adjust and utilize the best offset for every riding condition.
Take the stock SMR triple clamp 18-20mm offset, with the e-axle you get the adjustments from 16-22mm instead.
$160shipped
Thanks
Chris
Discussion Starter #2
Give your KTM a broader range of steering offset adjustments, + or - 2 degrees of adjustment in a minute. Take that 14 degree triple down another 2 degrees with this axle(12 degree triples at that point) - you get the idea. If you got every KTM bling piece this is the one of the last things you can add.
Also have: Left hand brake setup - give you handle bar access to the rear brake.
Cheers
