Red hot exhaust on 690 duke?
1 reading
6.3K views 7 replies 4 participants last post by  Pok Leh
#1 · (Edited)
Hi,
Just dropped the keys on the floor when warming up the bike and picking them up saw how the header pipe was red hot all the way down to de O2 sensor:headscrat:headshake
Went for a ride thinking it was the starter heating up the bike but on the way back, siting again at iddle for 1 min or so, the header would become red hot again.
Is this normal? why only at iddle? (air flow or running very lean at iddle)?
thanks,
#2 ·
If your exhaust got cherry red then your bike is leaning out bad. Of the 2 690's I have owned with over a combined 36,000 miles that has never happened to me. You might have gotten some bad fuel clogging the injector but the O2 sensor should pick that up. I have done the 15 minute idle reset many time and never had this happen also. Check your air filter for being clogged. Any FI light?
#3 · (Edited)
No FI light and apart from this bike runs fine. The bike is new (300 mi on it) and completely stock. Some other people have also found their 690's and 950's to become red hot. You have to take a look up the exhaust pipe to the cilinder with dim light to see it.
If bike was to run lean that would mean small amount of gas or too much air. Why do you say air filter clogged?
Anyone else with this issue?
#5 ·
so maybe it's normal at iddling right? At iddle bike apparently runs excessively lean.
Appart from iddle mine is fine. I've checked up the exhaust to the cilinder pulling aside the road and no signs of reddish color at all. Only at iddle.
#7 ·
same has said mine. Apparently it is normal. Quite surprising anyways.
1) Do you think excesive heat through exhaust valve might have something to do with rocker arm bearings issue?
2)would this mean running iddle the bike for long is not good?
some guys don't let the bike warm up at iddle, just run at low rpm's.
3) what do you think?
