Hey everyone. I picked up a set of warp9 wheels for my 2016 wr450f and am having a problem.
The rear wheel has about 2mm left and right play along the axle. I am using the plastic covered spacers from the original rear wheel.
I'm guessing I can just throw a washer I there? I was a little concerned about where to put it (in between the left swing arm and stock spacer?).
Also if anyone is curious in using stock brakes on the front. I swapped the rotors since the adapter plate that came with the warp 9 didn't fit the bigger brake caliper on the 2016.
I dunno as the Warp 9 hubs are designed for OEM spacers... I'd just call Warp 9 and get a fresh set of the right units from them directly.
I'm thinking that maybe the 2016 oem spacers are different than the 2012-2015 though or something. They are of course brand new. Either that or the swing arm width is larger.
