1 - 20 of 95 Posts
I bought this bike used. It started life as a 2002 crf450. It is plated street legal in CA. Someone already tarded it out with wheels and brakes. It was ridden hard and put away wet. I came to its rescue. It ran like crap and needed a lot of stuff to make it road ready. I am building it for my brother who wanted one just like mine that I got 6 months earlier. Mine is also a 2002 plated crf. This is my first post on sm junkie so bare with me.
I tore it apart only to find out it need a valve job, timing chain, bottom end rebuild and lots of other little stuff in the motor. Needed stator flywheel........ bottom line $2000 in just the motor :eek:
C.T. racing did all the work. He has built me 2 other motors and they run like champs.
Not surprising about the valves, the early Honda 450 valve seat material was garabage and they ate intake valves. Did u put stainless ones in when u had the head redone?
I like the balance between the black and aluminum frame and swingarm. IMO I think if you polished the $hit out of the frame and swingarm it would really set it off!
Discussion Starter #10
Everything was cake in grime and oil. Looks like it was never cleaned or maintained. Some simple green fixed all that. The rear shock had some miles on it
t
Discussion Starter #13
The wheels had some chain rub so Dr. John cleaned the up for me and they are as good as new. Ready for the powder coater.
Discussion Starter #14
I did some test coats with some pj1 motor paint. It looks good and almost matches the powder coating. Everything cant be baked so this will fill in the gaps.
Discussion Starter #19
I did go with s.s. valves just to be safe. ct did a five angle job on them and installed new guilds I am 75% done with it but just now starting the thread. I will post pics up as fast as I can.
1 - 20 of 95 Posts
