Hi everyone, ive got a 2004 gas gas fse450 and something strange happened. I took it down to the garage and notice it idling slightly higher than usual, when i put it on its side stand and it wanted to move gently backward. I thought i'd better take it home (200m away) but shorty after taking off it cut out. Everything went dead, fuel pump, lights horn etc. I pushed home and found 25A fuse blown, replaced that then started it. It went for about 2secs then cut out and went dead again although new fuse didnt blow. Im abit puzzled and the manual also has no electrical information in it. The battery had a healthy 12v. I'd appreciate any info.
SOUNDS LIKE YOU HAVE AN ELECTRICAL SHORT IN THE BIKE...START FROM THE SPARK PLUG AND WORK YOUR WAY FROM THERE. :headscrat YOU SAY THAT YOU REPLACED THE FUSE N THEN IT CUT OUT AGAIN....
check the side stand switch ?...its buggered up ?... take the two wires and wrap them \together..
