this was my first time changing the oil on my '06 625 smc. it has about 2200 miles on it, i bought it used..
i followed creeper's oil change method. everything went smoothly...almost...until i decided to burp the frame oil by loosely threading the bolt and tightening it when i saw oil ooze out past the thread. i did this. i was surprised the oil didn't come out immediately...it took about 15-20 seconds after i started the bike. i let the oil ooze out past the loosely threaded bolt for about 10 seconds and then tightened it. then i let it run a little bit (2-3 minutes) so i can check the oil level once it was warmed up again...but then it just shut off...
when i tried to restart it, nothing happened. it'll start when i give it a little throttle and push the start button. as soon as i let go of the throttle to idle on its own, it shuts off again.
i tried turning the idle control knob (clockwise) and it still won't start. i also tried restarting with the hot start knob pulled out and nothing. it only seems to start when i give it some gas with the throttle. btw, the choke knob is pushed in.
does anyone know what might be the problem?
did i not burp it properly? could that be it?
please help!!
please help!!
