The manual for my CRF150R says to replace piston, rings and pin about every 15 hours.
I use it for supermoto, not mx.
15 hours seems awfully soon, but would like input from those of you who know more than I do.
Also, when I do it, would it be a problem going to a little higher compression piston? If not, which one do you recommend?
Thanks much for the help!
15 hours:rolleyes:
Are you bouncing it off the rev limiter into turns and cruising at 10,000 RPM's?
I suppose for racing thats resonable...but man 15 hours:infrandom
That's a joke. 15 hours. Just keep the valves checked and keep an eye on oil consumption. If it starts blowing blue, put a piston and rings in it. If the vavles start to zero out consistently, it needs a new valve train. Some people over-think it and worry too much. The bike will tell you what it needs long before it goes kaboom.
Also, a higher compression piston should not be a problem. I don't know specifically on the 150, but a 250 seems to take one fine running on pump gas. - no pre-detonation.
X2 mines was a hi-comp piston too. runs fine on super but really loves some 100 octane
