So I did the yosh rs-2 full system, the 3x3 mod and the JD jet kit and the bike runs great. Only problem is that my buddy's 01 DRZ-S runs neck and neck with me. He has only the pro-circuit full system with no jetting or other mods, 14,000 miles on it too! The only difference is that i'm running my stock SM gearing and he has 15/47 on his. Any ideas? Should I change gearing?
15/47 will give you better acceleration, but if you cruise much at 55+ your rpm's will be up there pretty high. I'd try a 14 tooth front sprocket first, and see how you like it. that way you don't have to buy a longer chain either.
i dropped one in the front right when i got the bike.... it made it pull a lot harder but it REALLY SUCKS on the highway.. and i do a lot of highway riding so i took it off... great for the low end. shitty for the top end
I would leave it alone, but if you want a change I would either get a 14t front or 44t rear. The front is much easier to change and *shouldn't* require a change of chain length. The rear will.
15/47 isn't enjoyable on the steet IMO. Having ridden one, it's just too much shifting.
Remember, as most vehicles break in and loosen up they gain a bit of power. Your buddy's bike may be much better worn-in than yours :D
-Dave
what carb does that guy have?
What makes you think your SM should pull any harder than an older "S" model? If you are talking flat out drag race, his bike with a full pipe and stock jetting should be spot on at full throttle. Yours should run better at part throttle with smoother running and better throttle response.
I think his gear (15/47) presumably with stock wheels, is a little shorter than yours allowing him slightly better acceleration. The stock S gearing (15/44) is pretty equal with stock SM gearing once the taller rear wheel is accounted for.
FWIW, I have a buddy who has a stock '01 S which runs pretty close to my jetted and full Yosh Ti piped '03 S. Mine pulls away a bit, but not by much. And my S makes close to 40 hp (39.9 or something).
