Complete bike (now mostly disassembled) located at my house in Grand Rapids, Mi 49508. Blew motor (broke rod in half and it spun around and cracked case, displaced the crank to the right enough to knock a ring of casting off the case at the end of the crank and motor locked up immediately). Bike has around 1500 miles on it. Bike is stock with Akro exhaust, Pro-taper bars, and nice hand guards.
Title is clean and bike is paid off. All parts are available and in good working and looking order except cases, rod, (assume crank is bad, but don't know), and piston. Head is good, transmission is good, all other engine parts are good.
AVAILABLE:
lower end with cracked cases, and cracked cylinder, broken rod and pistons, but good transmission - $250
radiators - $150 for pair
passenger pegs - $50
pro taper bars - $30
pro taper bar mounts with pad and cover - $30
carbon fiber looking handguards for stock size bars - $50
full stock exhaust - $175
rear subframe - $50
stator and stator cover - $125
clutch cover - $30
clutch basket and whole clutch - $75
speedo cable - $20
everything else on a full bike that i can't think of right now...if it's not listed somewhere here it's for sale.
PM me what you think is a reasonable price. (not including shipping....you can estimate shipping...my zip code is 49508 and I'll take it to whichever carrier you request...but keep shipping seperate in the offer)
if prices offered are fair on those, they're gone. Will post as things are sold. I would prefer selling things in larger chunks, so please limit(read avoid) the small little nuts and bolts requests.
All updates will be done in this first post.
sledncycle has dibs on:
skidplate - $40
J.R. has dibs on:
starter - $100
SOLD ITEMS:
sledncycle (picked up)
18/21" wheels - $500 SOLD
J.R. ($65 shipping paid)
head - $200 SOLD
full Akropovich exhaust - $275 SOLD
carb - $200 SOLD
electric harness - $75 SOLD
side plastics incl fasteners - $40 SOLD
rear fender - $30 SOLD
headlight and front plate - $45 SOLD
cdi, capacitor, coil, batt cable, horn, rear harness, relay - $25 SOLD
bar controls - $30 SOLD
coolant overflow, battery tray, kickstand - $50 SOLD
alohar1: ($16 shipping paid)
kickstarter assembly -$100 SOLD
signal flasher - $20 SOLD
tls25rs: ($84.04 shipping paid)
clutch lever/clutch master/decomp lever/decomp cable - $100 SOLD
forks - $250 SOLD
triples w/bar mounts - $100 SOLD
gas tank/cap - $80 SOLD
swingarm, rear suspension linkage - $75 SOLD
rear shock - $175 SOLD
front brake assembly(caliper/hose/master/lever) - $100 SOLD
seat -$50 SOLD
front fender - $30 SOLD
juliodc123: ($8 shipping paid pending echeck clearing)
speedometer (works fine except backlight and side indicator lights) - $75 SOLD
roboboss: ($7.35 shipping paid)
throttle cable assembly - $40 SOLD
srad600: ($85 shipping paid)
clean street titled frame - $360 SOLD
