I have a KTM 500EXC-F i'm building into a 90% street bike with 10% track days. No dirt in the foreseeable future. I've already installed a JD fuel tuner, Arrow slip on, de-smogged the bike, installed 17" wheels with an oversized rotor. I'm thinking about what mod I should do next. I have narrowed it down to these options. Hinson slipper clutch, X-Trig triple clamps (stock offset is 22mm), or Berringer 6 piston caliper with a radial master cylinder. All are similar in price within a few hundred dollars. What would you guys do and why?
Beringers are top quality stuff. The stock caliper/master will probably be sufficient enough for your street use but depending on how hard you go at the track, you'll probably need the brake upgrade next.
That’s kinda where I’m leaning towards. It just seems like the biggest safety improvement. My last race SM build had the 6 piston Beringer caliper and rotor and it was awesome. It also had the stock triples and no slipper. Problem is I’ve owned a few sportbikes with slipper clutches since then and I really love the feel of a slipper lol. Also, with the stock 22mm triples on my bike now, I can really feel how the bike just wants to go wide in a turn. My other option is to take the adjustable 20/18mm triples off my dirt bike and run them on the 500. I know 18mm offset isn’t ideal either, but it should be a noticeable improvement over the 22mm triples.
slipper clutch is a Great thing to have on track
I agree 100% That's why it's such a difficult decision between the 3 options. I haven't needed more braking power yet, but I haven't done a track day with this bike yet either. I know it will need the braking upgrade on track days for sure. I'm a big guy and even on my last build, a YZ450 with the Beringer 6 piston caliper, Beringer master, Beringer solid rotor, and RBF600 fluid, I managed to boil the fluid on short tight tracks. There's no way the stock 2 piston Brembo will hold up on track. So then the next upgrade would be the slipper or triples.
