Just got the engine back in new piston (wossner) gaskets started up no bother apart from alot of smoke from the exhaust i thought it was just the oil burning of as it went after it warmed up.Now i have fired it up again its done the same but then i noticed oil coming out of the left hand exhaust header pipe.
any ideas will be welcome as im now sick as ****
thanks
Call whoever did the work and let them know what's happening.
It's tough to diagnose your exact problem over the net, I have my suspicions, but you need to talk to your mechanic ASAP!
unfortunately i did the work myself ive just had it running for about 20 mins there was a little smoke on start up but not as much as before but there is still a small amount of oil leaking from the header
Just wondering why you replaced the piston (and rings?) at 2000 miles?
Did you use the service manual to do the work?
destroyed fourth gear so decided while it was open id replace the piston save doing it later.
Followed the manual to the letter but its the first time ive done a four stroke so didnt know wether this was the norm till the rings seated properly
