im wondering if anyone may have a manual and would like to share some torque specs for a 08 ktm 690 smc, pretty much need all specs for complete motor. any help would be great!!!!
This is out of the '98-'05 LC4 manual.
Hexagon nut at primary gear M20x1,5 Loctite 243 + 170 Nm
Collar nut flywheel (LC4, ADVENTURE, DUKE) M16x1,25 links 150 Nm
Collar nut flywheel (SC, SXC) M12x1 left 60 Nm
Hexagon nut for inner clutch hub M18x1,5 Loctite 243 + 90 Nm
Collar bolt clutch springs M6 10 Nm
Kickstarter stop bolt M12x1,5 50 Nm
Allen head bolt freewheel hub (E-STARTER) M6x12 12.9 Loctite 2701 + 16 Nm
Allen head bolt freewheel hub (E-STARTER) M6x12.5 8.8 Loctite 2701 + 12 Nm
Allen head bolts oil pumps M6 Loctite 243 + 8 Nm
Collar bolts oil pumps (from modell 2003 on) M6 Loctite 243 + 10 Nm
Hexagon bolt camshaft gear M10 Loctite 243 + 35 Nm
Allen head bolts cylinder head top section M6x25/M6x35/M6x65/M6x70 (8.8) 8 Nm
Allen head bolts cylinder head top section M6x50/M6x55 (12.9) 15 Nm
Bolts cylinder head top section (from model 2003 on) M6 (8.8) 10 Nm
Bolts cylinder head top section (from model 2003 on) M7 (12.9) 15 Nm
Cylinder head to cylinder M8 25 Nm
Cylinder head to cylinder M6 8 Nm
Cylinder head to cylinder (from model 2003 on) M6 10 Nm
Cylinder head bolts M10 50 Nm
Cylinder head bolts (from the 2004 model) M10 10/53 Nm
Collar nuts at cylinder base M10 50 Nm
Plug at cylinder head (SC) M10 20 Nm
Hexagon bolt chain sprocket 8.8 M10 Loctite 243 + 40 Nm
Hexagon bolt chain sprocket 12.9 M10 Loctite 243 + 60 Nm
Nut chain sprocket M20x1,5 Loctite 243 + 60 Nm
Oil drain plug M22x1,5 30 Nm
Magnetic plug M12x1,5 20 Nm
Plug Bypass valve M12x1,5 20 Nm
Banjo bolts oil lines M8x1 10 Nm
Banjo bolts oil lines M10x1 15 Nm
Jet screw clutch cover M8 10 Nm
Plug timing-chain tensioner M12x1,5 20 Nm
Timing-chain tensioner to cylinder M6 Loctite 243 + 8 Nm
Timing-chain tensioner to cylinder (from model 2003 on) M6 10 Nm
Timing-chain guide to cylinder M12x1,25 Loctite 243 + 8 Nm
Hexagon bolt timing-chain guide M6 Loctite 243 + 10 Nm
Tension guide M8 Loctite 243 + 15 Nm
Timing-chain securing guide M6 8 Nm
Allen head bolt timing-chain securing guide (from model 2003 on) M6 Loctite 243 + 10 Nm
Counternuts valve adjusting screws M7x0,75 16 Nm
Crankshaft locking bolt M8 20 Nm
Spark plug M12x1,25 20 Nm
Engine mounting bolt M8 40 Nm
Engine mounting bolt M10 70 Nm
Retaining plate for main shaft bearing M6 Loctite 648 + 8 Nm
Retaining plate for main shaft bearing (from model 2003 on) M6 Loctite 648 + 10 Nm
Shift mechanism support, securing device for bearing M5 Loctite 243 + 6 Nm
Shift mechanism support M6 Loctite 243 + 8 Nm
Shift mechanism support (from model 2003 on) M6 Loctite 243 + 10 Nm
Shift drum locating M6 Loctite 243 + 8 Nm
Engine housing, clutch cover, ignition cover M6 10 Nm
Water pump cover M6 10 Nm
Bolts for pulse generator M5 Loctite 243 + 6 Nm
Stator (SC) M6 Loctite 243 + 8 Nm
Stator (E-Start) M5 Loctite 243 + 6 Nm
Kick starter M8 25 Nm
Shifting lever M6 Loctite 222 + 10 Nm
Oil filter cover M6 10 Nm
Microfilter cover (SC) M5 6 Nm
Starter flange, starter cover M6 10 Nm
AH bolt for slave cylinder M6 Loctite 243 + 10 Nm
Starter M6 10 Nm
Valve cover M6 10 Nm
Exhaust flange M6 10 Nm
AH screw for decompression shaft lever M6 Loctite 243 + 10 Nm
Retaining shim for ignition (SC) M5 Loctite 243 + 6 Nm
Contact screws M10 15 Nm
Oil jet M6x0,75 Loctite 648 + 10 Nm
Plug for gear detection sensor M10 25 Nm
Water pump wheel M5 Loctite 243 + 6 Nm
Thermostat case M6 6 Nm
Closing panel for ignition (SC) M5 Loctite 243 + 6 Nm
Pulse generator M5 Loctite 243 + 6 Nm
Other bolts, engine M5 6 Nm
M6 10 Nm
completely different motor so that won't do him any good.
out of an '08 690 enduro service manual, same should apply to the smc.
SKULLY25 thank you so much this will be much help in getting my bike back together!:bannana: definatly missing it
