So i got this Husqvarna SMR 510 and i am trying to build a handbrake setup.
So the problem is that the braking is very bad. I have tried to pull the lever with both hands and it just barely lock up the tire. My master cylinder is from a Suzuki GSXR 750 and my caliper is the stock one piston brembo. So is my caliper the problem? Do I need a bigger rear caliper. I have bleed the system multiple times and there is no air in the system. There is also pressure when i pull the lever.
Soory for bad ENGLANd
