1 - 13 of 13 Posts
2009 wr250x fmf programer,fmf q4, ais removed,air boxed opened up..
bogs than runs good for a minute ,bogs than runs.......no power on freeway..
my bike got kinda quit and dont feel much air coming out of the pipe??
just went out and looked the exhuaste pipe is leaking around the lower part of the can!!!
wtf is this my power loss??
is their packing in the fmf? got clogged up??
The last guy (on WR250Rforum.com) that claimed what you are says that filling-up with some fresh gas took care of his problem.
He may have drained the old stuff out, first, but I can't recall.
How does your air filter look?
Look inside the airbox, don't just peer in from the top inlet.
You sure something isn't stuck down inside your pipe? Dead mouse?
A leak in pipe at can shouldn't be a huge issue, but if the packing, or something else has clogged pipe you would get that.
Take the can apart.
That's where I'd start.
And the airbox is a good and easy place to look as well.
A member at another forum has had insane mouse issues with airbox.
Perhaps you have one in your exhaust canister?
Packing was all clogged up!!! Thank you!! Maybe I got it wet?? I don't have a lil exhuast plug yet..
I ruined the spark arestor can I buy that as a operate part
Call FMF they will get you hooked up quick, called them for decals and such for my can when i made my undertail and had the stuff 2 days later.
find something to plug your exhaust when you wash it and replace your packing now, if its gotten wet its gonna be junk. its cheap get new.
Take the screen out of the end and turn it around,all that little pink fuzz you see cloged it up slowly over time and cannot be seen from the end looking into the pipe.
I removed mine one day to see how much louder it made the bike and was amazed how small the hole was. And how much better it ran after i cleaned it out.
Discussion Starter · #11 ·
yep it was just the packing!!!!!
rode to work with no screen or packing today!! lil on the loud side!
ill give FMF a call!
thanks
1 - 13 of 13 Posts
