filthyboatguy said:Where is the drain hole?
Nope, our club doesnt require a radiator overflow catch, only that we use water.. I suppose if they decide to, its just a matter of another 1.49 for 20' of hose and another hole.. :thumbup:Extreme said:does the radiator overflow hose go there too?
I just hate it when people try to weld on my nipples.bdmmotard said:very nice indeedy. did you just drill holes, or weld on nipples?
Ive ran the heck out of it with no problems.. The dump is at the back where the axle is and every time i pull the plugs, I get A LOT of gas that comes out..Canadian_SMR said:Inside the swing arm does the cavity extend back to where the axel is or does it just contain it in that front area right under the tubes? as well do the tubes still have an ability to breath ? if heard bad things about cloged lines
I suppose if you have watery gas it would.. :lol:2004 hondaCRF150F said:SO let me get this straight, YOu drilled holes in the front of your swingarm and stuffed the hoses in it. And so that way if it spills it goes on the inside. and then you have a plug on the bottom to leak it out. What about rusting the inside. I have a steal swingarm on my 150 i think. will it rust the swingarm if i did this.
Yes, but im changing it to this next time I work on the bike.bdmmotard said:Eddie, you still using this setup? where you running your engine breather to?
