Installed GRP slip on left baffle on pipe as it made more power had to re drill baffle....install the Magnum tuner ....piece of crap...no gains lost 2hp ..took off air box lid and filter back to 65hp and 5lbs more torque ...but went lean ..so doing air box delete and power commander 5 ...with adjustable timing ...should see a solid 70-72 hp and 56lbs torque ... and more over rev ..will keep everyone postedThanks for sharing, impressive !
Hum ...65 Hp ? there is 2 missing...
Please tell us more when you got the Magnum dyno !
It was 65 to the wheels ...they list at 67 at crankshaft out put so a loss of 2hp not bad ...just installed power commander 5 from a 2015 KTM model 690 smc and re-wired to allow me to use the PC5 controller for fuel and ignition adjustments . I down loaded a base map for now very impressed by seat feel very responsive already can not wait to tune...Thanks for sharing, impressive !
Not only do Dynos read differently and air density introduces another variable, there are 3 HP numbers commonly quoted:It was 65 to the wheels ...they list at 67 at crankshaft out put so a loss of 2hp not bad ...just installed power commander 5 from a 2015 KTM model 690 smc and re-wired to allow me to use the PC5 controller for fuel and ignition adjustments . I down loaded a base map for now very impressed by seat feel very responsive already can not wait to tune...
Hello 701guru,It was 65 to the wheels ...they list at 67 at crankshaft out put so a loss of 2hp not bad ...just installed power commander 5 from a 2015 KTM model 690 smc and re-wired to allow me to use the PC5 controller for fuel and ignition adjustments . I down loaded a base map for now very impressed by seat feel very responsive already can not wait to tune...
I will put some pictures up tonight my other computer kept kicking me off ...no worries already have the pc5 wiring schematic to fit the 701 it's easy and I will be tunning without auto tune so I can do a lot of timing adjustments then add fuel.Hello 701guru,
This is coming more and more interesting !
Thank you for the feedback on the Magnum tuner.
I suspected 2015 ktm power commander to be compatible with 701...
Will you use "auto tune" or make your own map on the dyno ?
In both cases you will be able to provide good mapping ...
...And maybe a little help when I 'll install mine......
(I've allready installed and used a PC5 on my 510... Quite simple... )
This is more scheduled for september for me... This will give you more time to improve your tuning ! :lol:
Thanks again ! :thumbup:
Looking forward to hearing their response! If worst comes to worst, I don't mind messing around with software, that's what I do for work anywaysWon't be long mine has been used for development now.. I will ask them, the DynoJet guy said polarity on the injector was diffrent to the 690 but also injector cycle and duration timing. He had to change something in the software to correct this, development software not something Joe blogs can do..
Looking forward to hearing their response! If worst comes to worst, I don't mind messing around with software, that's what I do for work anyways![]()
Good to know, now I know what to expect!They were all done without any baffle, I thought about a map with the baffle in for track days etc but I forgot to take them with me![]()
Great info LCR, thanks for sharing!!Its a good question and yes I do! The second line (yellow) is just the Wings nothing else.
Do you have AFR readings for different mods or for any of those dyno runs?Its a good question and yes I do! The second line (yellow) is just the Wings nothing else.
