1 - 20 of 20 Posts
Hi friends of KTM!
I want to show you my 690
it's a normal SM and not a SM-R, i've done the changes before KTM launches the SMR
Please tell me what you think about
Next to do is the exhaust from the Duke 690
at this time there is no possibility to buy a aftermarket, i think.
In Austria, where i am living, you had to mount an exhaust with homologation.
So there is just one opininon - the stock
Make sure you use the Duke forks and shock, too!
8.3" of travel with 9.6" ground clearance + ~4" of underhanging muffler = about -2.7" of ground clearance under full compression. If you've ever ground hard parts at speed it's not a fun thing. The muffler could drag hard simply by getting hard on the brakes which could unload the front tire, or worse. Not a good thing.
Since you've got a hugger front fender why not cut off the duckbill or use a Duke headlight assembly?
if i will use the duke headlight, i should have bought the Duke before.
but i want to have the "DUCK" in the front, my nickname told you so, too :lol:
but i've got the backlight from the Duke, maybe you can see this on the picture
i also know the problems with the hight, but my weight is just 69 kg, don't you think this will work with the stock suspension?
aye what fender is that >? ( on the front )
edit: WHOA that silencer ( SM Project ) and headers claim an approx 9kilo weight reduction - thats 19.823788546255507lbs american ! :clap::eek:
1 - 20 of 20 Posts
