Mint cond. caliper and rotor. The rotor has no wear, you can't feel any grooves in it at all. The caliper has no scratches and comes with used pads and I do have the pin for the pads. I had to order a new one cause I lost the original. I'll throw in the braided steel line, because nobody in the world should use a rubber line. It was used very little then the bike was ripped apart to do a 500af conversion. I bought a beringer setup instead of using this again (only because it's anodized red) $450 shipped in the 48 or canada.
